Check compatibility to V5.X option
When using the "Check compatibility to V5.X" option in the Scene > Load/Save Options menu, how are we notified about the outcome of the compatibility check? Does a message appear only when a scene is not compatible? There isn't much information about this in the documentation.
Re: Check compatibility to V5.X option
Even though I had "Check compatibility to 5.2" checked, I didn't receive any warning and the scene doesn't open in 5.2. I get the attached "Couldn't create or open scene. Type 'Ventuz.Kernel.Layers.LayerCameraDefinition' not found! Your scene was saved with a newer version: 5.3.0.112"
- Incompatible Scene.png (4.7 KiB) Viewed 3386 times
I got the same problem.
Additionally, how can I roll-back a scene from 5.3 to 5.2?
