I would love to have a shortcut key to toggle the Statistics and Input Diagnostics visibility, so I don't have to switch to the Desktop/Config Editor every time.
It would be a benefit especially for calibrating touch frames, where you have to clear the Incoming Touchpoints quite often.
Thank you in advance, Eric
Statistics and Input Diagnostics Shortcut
Re: Statistics and Input Diagnostics Shortcut
hi eric
are you talking about designer or runtime?
in the designer it is just 2 clicks away
Yeah, but it would be nice to stay in fullscreen, especially in the presenter.
But I know there are already a lot of shortcuts and you can't shortcut every single function in ventuz.
- Dierk Ohlerich
You can use the Live Options in the Ventuz Config to change the debug settings. If you are running full-screen and no second screen is available, this can be done remotely from a second computer. (The button is located directly below the machine selection popup in the top right corner.)
We try to minimize the keyboard shortcuts in the presenter because they might interfere with the interaction that some users might have programmed. Even unusual combinations with CTRL might be a problem. When we added the Pause, Page Up & Down keyboard commands to the performance statistics we made sure they do not disturb existing interactions when the performance statistics are disabled.
-- Dierk Ohlerich
Just Use the TCP/IP node and set the LiveOption via VMS service
Message: OPT REN.Stats true
EndOfText: CRLF
hi daniel
perfect thx!
here a little vza to switch on/off mouse and stats
perfect thx!
- ShowStats.vza
- (7.19 KiB) Downloaded 529 times
