M-AUDIO ProFire 610 - crashes Ventuz
Posted: 08 Sep 2014, 11:49
by morlowski
Hi everyone.
This is my first post.
I have an external sound card ProFire 610. In stereo mode works perfectly. As soon as I switch it to multichannel mode and try to run Ventuz, this crashes.
The strange thing is that in the Configuration Editor shows all 10 channels.
Please help.
Re: M-AUDIO ProFire 610 - crashes Ventuz
Posted: 09 Sep 2014, 09:57
by Dierk Ohlerich
I was able to reproduce the problem. This should be fixed in the upcoming Ventuz 4.05.00 release. In the meantime, you should try to configure your interface to 8 (mono) channels, if that is possible.
For best quality and performance, all audio should be configured to 48000Hz. This is what Ventuz uses internally, thus avoiding sample rate conversion.
The bug is a little bit complicated, if you configure to 48000Hz and 10 channels, it should not crash, but audio will be silent, at least that is my analysis.
Posted: 11 Sep 2014, 11:59
by morlowski
Thank you very much for checking this error.
You have 100% right.
After switching to 48 kHz sampling rate, Ventuz stopped crashes. As predicted card does not emits a sound.
Unfortunately I can not switch cards in 8 channel mode.
I have to wait for the patch.
When you plan to release version 4.05.00?
Posted: 12 Sep 2014, 12:24
Release is scheduled for 23. Sept. 2014 !
Posted: 25 Sep 2014, 07:29
by morlowski
I installed version 4.05 - here everything works perfectly - thank you.
Michael
