Movie giving green pixels to Right
Posted: 09 Oct 2013, 19:26
by joysprod
I have found a problem with the movie nodes where a thin green line is visible to the right if I use the 2d Mapping to move the texture in X. If I have the UVW set to wrapping, I cant get an invisible tile as this green line is very visible. The video was exported out of After Effects.
I have enclosed one frame of the movie file so you can test it as well as a screen grab.
regards
peter
Re: Movie giving green pixels to Right
Posted: 09 Oct 2013, 19:55
by joysprod
Forgot to say. This is not as pronounced in V3. Its a slight black line, not green!
My work around for anyone experiencing same is to use a render target and zoom slightly in X. Then take the output and map onto required polygon.
Posted: 10 Oct 2013, 09:09
by Daniel Willer
It seems to be a probleme in the movieclip if I open the clip in Quicktime there is also a green line.
Posted: 10 Oct 2013, 09:44
In Windows Media Player as well!
Posted: 10 Oct 2013, 10:14
by Dierk Ohlerich
We have tried Quicktime, Windows Media Player and ffplay, and they show the same result, so this problem is not specific to Ventuz.
The video has a width of 1906 pixel, and is encoded with h264. H264 usually uses a block size of 8x8, so I suggest you try re-encoding the video with a width dividable by 8, like 1920 or 1912 pixel.
