Deltacast output card for fill and key purpose provide interlaced fields in bad order.
Robert
Inversed interlacing
- Dierk Ohlerich
Re: Inversed interlacing
Can you please tell me which video format are you using and which device are you using to view the signal? That would help reproducing the problem.
Thanks in advance,
Dierk.
Thanks in advance,
Dierk.
-- Dierk Ohlerich
The SDI board is the delta hd-e key 22. We use it with this resolution 1080@50i.
The device we used to view the signal is a kahuna.
R
R
