Hi
I am using an XML Text node to pull some data from a web site. I do this with a C# plugin which returns XML, (and sets changed == true). This is fed to the input of the XMLText node, but the output is not updated unless I change the NS1 field of the node. Is this normal? How can I update the output value? Ventuz v4
Data not passing through XML Text node
Re: Data not passing through XML Text node
This WAS my problem in the C#. I wasn't updating the right variable! All is good.
