Removing Output shows wrong size render window
Posted: 24 Sep 2013, 15:01
Configuration Editor: Create a 3 monitor (3 x 1) set up.
In Designer, Confirm that Project properties Format is at 5760 pixels.Go to Designer and create a scene using this above selection in the stage editor. All looks ok in Design and Production Preview settings.
Return to Configuration Editor and remove the right hand monitor. Save.
Back in Designer, Confirm that Project properties Format is now at 3840 pixels.
All looks fine in Design preview, but switching to Production Preview shows a ghost (black Screen) of where that monitor was?
Returning to the Configuration Editor, select the two monitors and delete them. Create a new 2 monitor set up, and you will find that this displays correctly in Designer with both Design and Production Previews.
