Hey all,
I would like to be able to control three different machines using a single app Which I have successfully done. It is all fine when I want to run the presentation with the same content. But I would like to be able to have control of the content on each machine. e.g some instances I may want to have the same content or I may want the content to be different but trigger at the same time.
* Is it possible to have different contents?
*How to access each machine separately?
eg. cluster[2].... will access machine three.
Is there any example projects floating about?
or any advice or direction would be appreciable.
Ventuz Remoting4
Re: Ventuz Remoting4
You should be able to create 3 clusters to do this:
public void InitClusters()
leftCluster = new Cluster { Name = "Left" };
leftCluster.AddMachine(new System.Net.IPEndPoint(System.Net.IPAddress.Parse("192.168.1.101"), 19400));
leftCluster.Start();
middleCluster = new Cluster { Name = "Middle" };
middleCluster.AddMachine(new System.Net.IPEndPoint(System.Net.IPAddress.Parse("192.168.1.102"), 19400));
middleCluster.Start();
rightCluster = new Cluster { Name = "Right" };
rightCluster.AddMachine(new System.Net.IPEndPoint(System.Net.IPAddress.Parse("192.168.1.103"), 19400));
rightCluster.Start();
You could also create an array which will make it easier to iterate through all clusters:
Cluster[] machines = new Cluster[3];
for (int i = 0; i < machines.length; ++i)
machines = new Cluster { Name = "Machine " + i };
machines.AddMachine(new System.Net.IPEndPoint(System.Net.IPAddress.Parse("192.168.1.101"), 19400));
machines.Start();
In this example you will need to provide an array of IP addresses (String[] machineIPs) and use that array in the AddMachine command:
machines.AddMachine(new System.Net.IPEndPoint(System.Net.IPAddress.Parse(machineIPs), 19400));
Hope this helps,
Etienne
machines.Start();
Hope this helps,
Etienne
Thanks, Etienne!! It works!!
In addition, I also came across a Class call multiport which manages cluster
