Gouraud shader
VincentPix
Gouraud shader
Hi
Is there somewhere the template for gouraud shader in Ventuz ?
including textures, material, lights,...
I want to do a custom vertex noise for an object with gouraud or phong shading.
TVM Cracklings
Re: Gouraud shader
This could probably help.
VincentPix
Re: Gouraud shader
hello
I've got a strange result with this shader (same code than in the "lit" topic with the corrections as indicated. I also delete the direct color on the shader and use instead the diffuse of the material.
If you try it, you'll see that it gives a picture with strange colors(Red for diffuse and a yellow specular) instead of grey levels (light and material are set to white except ambiant and emissive, set to black)
Does someone have a hint to correct this problem ?
thanks
#define pi 3.14159265358979324
float4x4 mMVP : WORLDVIEWPROJECTION;
float4x4 mMV : WORLDVIEW;
float4x4 mIMV : WORLDVIEWINVERSE;
struct VDL{
float3 D;
float3 S;
float3 A;
float3 vDir;};
struct VPL{
float3 D;
float3 S;
float3 A;
float3 vPos;
float3 vAtt;
float Range;};
struct VSL{
int Type;
float3 D;
float3 S;
float3 A;
float3 vPos;
float3 vDir;
float3 Att;
float4 FalloffO2I;};
struct VL{
int Type;
float3 D;
float3 S;
float3 A;
float3 vPos;
float3 vDir;
float3 vAtt;
VDL DL[8]< string SasBindAddress = "Ventuz.DirectionalLight[*]";>;
VPL PL[8]< string SasBindAddress = "Ventuz.PointLight[*]" ;>;
VSL SL[8]< string SasBindAddress = "Ventuz.SpotLight[*]" ;>;
VL L[8] < string SasBindAddress = "Ventuz.Light[*]" ;>;
int DLCount< string SasBindAddress = "Ventuz.NumDirectionalLights" ;>;
int PLCount< string SasBindAddress = "Ventuz.NumPointLights" ;>;
int SLCount< string SasBindAddress = "Ventuz.NumSpotLights" ;>;
int LCount< string SasBindAddress = "Ventuz.NumLights" ;>;
struct a2v{
float4 vPos : POSITION0;
float4 vNormal : NORMAL0;
struct v2f{
float4 vPos2 : TEXCOORD1;
float4 vPosVS : TEXCOORD0;
float4 vNormalVS : NORMAL0;
float Alpha < string SasBindAddress = "Ventuz.Material.Alpha" ;>;
float sp < string SasBindAddress = "Ventuz.Material.Sharpness" ;>;
float3 c < string SasBindAddress = "Ventuz.Material.Diffuse" ;>;
v2f vert(a2v Input){
float4x4 mITMV = transpose(mIMV);
v2f Output;
Output.vPos = mul(Input.vPos, mMVP);
Output.vNormalVS = mul(Input.vNormal, mITMV);
Output.vPosVS = mul(Input.vPos, mMV);
Output.vPos2 = Output.vPos;
return Output;
float4 frag(v2f Input) : COLOR{
// Directional Light:
float3 n = normalize(Input.vNormalVS.xyz);
float3 l = -normalize(DL[0].vDir);
float3 v = normalize(Input.vPos2.xyz);
float3 h = (l+v)/2;
float4 LCoef = lit(dot(n,l),dot(n,h),sp);
return LCoef*float4(c,Alpha);
technique tech0{
pass pass0{
vertexshader = compile vs_3_0 vert();
pixelshader = compile ps_3_0 frag();
ZEnable = TRUE;
thanks
Re: Gouraud shader
You're using lit() which returns several lighting coefficients in one vector. See here for details. Then you multiply the coefficients with your color:
return LCoef *float4(c,Alpha):
r * 1
g * diffuse coef
b * specular coef
a * 1
What you need to do is use the correct coef for the correct light and material component. Have a look at the light equation. Also you're ignoring all colors expect for the diffuse color anyway
If you do:
return LCoef.y *float4(c,Alpha);
You'd get a gray gradient. But you're still ignoring the light color for the diffuse channel. And the other channels (ambient, specular, emissive). You should multiply material.diffuse with light.diffuse and the diffuse coef. Same for the others. Sum up the results. Well, see light equation for all the details
cheers,
r * 1
g * diffuse coef
b * specular coef
a * 1
If you do:
cheers,
VincentPix
Re: Gouraud shader
Thank you very much !!
(I feel stupid now I have the explanation)
VincentPix
Re: Gouraud shader
Did this
(support only Directional Lights type but can handle 8 sources. Manage only one texture for now. But the lighting fx seems quite good)
I'm trying now to manage all textures and mapping in this shader but I've not found for now how to do and where to do a loop on the sampler for each texture.
to be continued...
struct VDL{
float3 D;
float3 S;
float3 A;
float3 vDir;};
struct VPL{
float3 D;
float3 S;
float3 A;
float3 vPos;
float3 vAtt;
float Range;};
struct VSL{
int Type;
float3 D;
float3 S;
float3 A;
float3 vPos;
float3 vDir;
float3 Att;
struct VL{
int Type;
float3 D;
float3 S;
float3 A;
float3 vPos;
float3 vDir;
float3 vAtt;
float4 TexSize[8] < string SasBindAddress = "Ventuz.Textures[*].Size"; >;
float4x4 TexMap[8] < string SasBindAddress = "Ventuz.Textures[*].Mapping"; >;
uint4 TexInfo[8] < string SasBindAddress = "Ventuz.Textures[*].Info"; >;
int TexCount < string SasBindAddress = "Ventuz.NumTextures"; >;
texture Tex <
bool SasUiVisible = false;
sampler Samp = sampler_state
Texture = (Tex);
MipFilter = LINEAR;
MinFilter = LINEAR;
MagFilter = LINEAR;
struct a2v{
float4 TexCd : TEXCOORD0;
struct v2f{
float4 vPosVS : TEXCOORD2;
float4 TexCD : TEXCOORD0;
float AlphaCol < string SasBindAddress = "Ventuz.Material.Alpha" ;>;
float SharpCol < string SasBindAddress = "Ventuz.Material.Sharpness" ;>;
float3 DiffCol < string SasBindAddress = "Ventuz.Material.Diffuse" ;>;
float3 SpeCol < string SasBindAddress = "Ventuz.Material.Specular" ;>;
float3 AmbCol < string SasBindAddress = "Ventuz.Material.Ambient" ;>;
float3 EmiCol < string SasBindAddress = "Ventuz.Material.Emissive" ;>;
v2f Output;
Output.TexCD = Input.TexCd;
return Output;
float3 l;
float3 h;
float4 LCoef = float4(0,0,0,0);
float4 AllLCoef = float4(0,0,0,0);
float3 DiffL = float3(0,0,0);
float3 SpecL = float3(0,0,0);
float3 AmbL = float3(0,0,0);
for( int i = 0;i < DLCount; i++ )
l = -normalize(DL[i].vDir);
h = l; //h = (l+v)/2;
LCoef = lit(dot(n,l),dot(n,h),SharpCol);
AllLCoef += LCoef;
DiffL += LCoef.g * DL[i].D;
SpecL += LCoef.b * DL[i].S;
AmbL += DL[i].A;
// Textures:
for( int j = 0;j < TexCount; j++ )
float4 ColTex = float4 (0,0,0,1);
if (TexCount > 0)
{ ColTex = tex2D(Samp, mul(Input.TexCD, TexMap[0]).xy);}
float3 Amb = AmbCol + AmbL;
float3 Diff = AllLCoef.g * DiffCol * DiffL;
float3 Spec = AllLCoef.b * SpeCol * SpecL ;
float4 ColOut = ColTex * float4(Amb + Diff + Spec + EmiCol , AlphaCol);
return ColOut;
technique tech0{
pass pass0{
ZEnable = TRUE;
to be continued...
Re: Gouraud shader
a long time ago, we posted a sample shader. It wasn't perfect, had a few bugs, but maybe this helps.
