Gopro Hero4 with Blackmagic IntensityPro 4K
Poly Kim
Post by Poly Kim » 18 Apr 2016, 11:43
hi, this is what I am trying to do.
#1 and #2 are set-up for Gopro and Blackmagic SW, respectively.
#3 is captured screen in Blackmagic SW. You can see it works well. It is 1920*1080p 59.94
This is Ventuz Configuration.
And, there is nothing I can see in Ventuz. The pic shows PLE but it was same with designer dongle.
[/size]
Is input signal what I need to configure in Ventuz different from the input in Blackmagic SW?
If so, how can I figure out the format of live input in Ventuz Configuration?
The cable is not a problem on the ground that I can see captured screen in Blackmagic SW.
Poly
Poly Kim
Re: Gopro Hero4 with Blackmagic IntensityPro 4K
Post by Poly Kim » 18 Apr 2016, 13:32
I tested with decklink duo and it works well. But, I cannot make it work with intensityu pro 4K.
Does Ventuz have any specific model of Blackmagic what it supports?
Poly
