In my project, I'm trying to create a script that will be called when a button is touched, and will return the co-ordinates of an axis attached to said button (which has been exposed to the scene data), and then move to that point. I plan for the script to output, using the scene data, the value of the X, Y, and Z axis values of the button touched, based on the ID of the node touched, something like this:
public bool OnReturnNodeValues(int arg)
NodeID = //get the id of the node touched here
string[] address = new string[] {NodeID + "/X", NodeID + "/Y", NodeID + "/Z"};
object[] XYZ = new object[]{null};
GetNodeValues(address, XYZ);
//set output values using object XYZ
return false;
public void GetNodeValues(string[] Address, object[] Values)
IScriptScene scene = this.Scene;
scene.Get(Address, out Values);
Let's say one node is called 'One'. If I touch 'One', I'd like the NodeID to be set to 'One', and then I can get the X, Y and Z values from scene data, and feed them into another node in my scene.
However, I'm not sure how i would get the 'NodeID' for a node from a touch, and I'd like to know how.
