lerou wrote: So I need to set the two machines to client and master, respectively. Or two machines are set to single?
Question is, what are you doing?! The Master/Client setting you're talking about is used for the interaction (TUIO).
If you're just using OSC to control things (like starting an animation) that has nothing to do with that setting. In that case you just send your OSC signal to all cluster machines - by using Multicast. The cluster sync is implicitly active if you set up your cluster correctly (same group ID, different IDs for the machines). The lowest ID becomes the master for the cluster clock.
Best,
cy001316 wrote:
Thank you for your reply.
I was a novice, is a beginner, the first use of ventuz cluster rendering, I want to do is to use OSC control in the cluster two machines. Now the problem is that OSC can only control a machine,if I do not use multicast address, can achieve?
as lerou mentioned, the master/slave has nothing to do with OSC and it will be configured during the machine ID's... If your controlling OSC software is not able to use multicast, you must use the OSC instruction twice. One with the IP from machine one and the other with the IP of the other machine. May be you can configure a batch or something, that both commands will execute short one after another.
