Shape Editor that works temporarily.
Poly Kim
Post by Poly Kim » 25 Sep 2015, 16:16
hi,
Let me ask a question.
I need to know if there is any "default" setting for shaping with ventuz
Two machines in same network, one is laptop for shape remoting, the other is Ventuz contents.
Usually, I don't have problem with the setting above. But, on the specific machine, the shape editor does not work at all. Only when I set as "Production Preview" in Stage Editor, I can adjust shape with remoting from laptop.
However, as soon as I close the shape editor window on remoting laptop, the Ventuz contents turned into the look before it was shaped. This means, shape editor with remonting works ONLY temporarily.
What matters is, I don't have this problem with other machines.
Only with two of specific machine among I have, this happens. :o :(
Ventuz 4.07, same network, no firewall
Machine : i5, Radeon R7 360, 8G Ram
Laptop : i5
I think this is quite awkward. If there's something I'm missing, feel free to let me know.
thank you
Poly
Götz_B
Re: Shape Editor that works temporarily.
Post by Götz_B » 28 Sep 2015, 13:29
Hi Poly,
first of all you shouldnt have the remote machine running in Designer.
Your problem sounds to me like you need a deeper understanding of MachineID's and RenderSetup ( and also the StageEditor/SceneManagement in Designer).
http://www.ventuz.com/support/help/late ... ering.html
http://www.ventuz.com/support/help/late ... tageEditor
Poly Kim
Post by Poly Kim » 07 Oct 2015, 10:06
hi,
Yes, machine ID was the answer. :)
thx!
Poly
