I have found this in the forum archive:
http://forum-archive.ventuz.com/forums/ ... tPost.aspx
Very nice
But how can i get this Windows form work together with the buildin OSC-Nodes in Ventuz?
I have tried to setup up a Ventuz OSC-In Node to receive from the windows form, see pics
The original Project was build with Visual 2008, I have converted to Visual 2012, because I need some async operations.
Do i miss to setup the correct ports?
tia, joschy
Help with OSC remote
Re: Help with OSC remote
hi joschy,
as i told you: osc remoting has NOTHING TO DO with controling ventuz by osc nodes!
but what i see is missing:
you have no ip int the osc nodes! so if you send to ip 230.230.230.230 what is a multicast adress you need to make sure, that you adjust the osc in node in ventuz to this adress!
O.K. rtfm...
"OSC Remoting is a very simple Open Sound Control based protocol to control DataItems of the SceneData. It only controls the current scene loaded in Port 0 of the layout scene in pipe 0. It is unable to manage scenes or Templates. "
A miss understanding from my side
I thought i can communicate with the Ventuz OSC Nodes this way.... so i have to implement it on my own
