DVI Input dropping frames
joysprod
Post by joysprod » 07 Nov 2014, 10:58
I'm having an issue with a DVI input card causing Ventuz to intermittently stall. This is happening in Runtime.
Are these issues written to a log file, and where can I fined it?
Dierk Ohlerich
Re: DVI Input dropping frames
Post by Dierk Ohlerich » 10 Nov 2014, 13:23
Do you have created an audio-video config or running you on the default "none" config?
If you have created an av config, is the input set to "synchronized" (it should not), and what output device are you using? (SDI?)
-- Dierk Ohlerich
