I'm trying to show the stats while running a presentation (not in the designer). Can't figure out how this is supposed to go... I vaguely remember I used to be able to do it in V3 with the the following line in the command shell, but with Ventuz4 apparently that doesn't work anymore:
start C:\mypath\mypresentation.vpr -stats
sq
Show stats in Ventuz4 presenter?
Re: Show stats in Ventuz4 presenter?
the command line options still work:
http://www.ventuz.com/support/help/late ... tions.html
You also can turn the stats on and off from a remote machine via the Configuration Editor. Select the runtime machine from the drop down on the top left and go to the Live Options.
Regards,
Götz
Regards,
Götz
I think I found my error. If called from a .cmd-file this will start the presentation, but without stats:
this will start the presentation with stats:
So it's the "start" command... I'll really have to look into that command shell thing again...
sq
start "C:\Program Files\Ventuz Technology Group\Ventuz 4\VentuzPresenter.exe" "D:\mydirectory\mypresentation.vpr" -stats
sq
