I cannot add audio crosspoints when using internal hardware keyer, the only option to specify crosspoints is when I choose internal SW keyer, and in that mode, my scene doesn't render, only bg-video on the output.
Same issue in 4.02 and 4.03
SDI board = DeltaCast Hd-key-22
Bug or is it me that doesn't understand the config editor?
// Sam
Audio crosspoints
- Dierk Ohlerich
Re: Audio crosspoints
With the deltacast keyer, you can only choose to either loop through all ancillary data from the input or replace all ancillary data with new ones. It is not possible to mix audio. Although the next Deltacast drivers & SDK (5.15) will have a feature that allows selective overwriting of ancillary data, that doesn't allow audio mixing, too. I assumed that overwriting all ancillary is not so useful and did not provide possibility to put an audio crosspoint on internal keying.
None of the board we support feature a hardware audio mixer (Deltacast, DVS, Datapath, Black Magic).
The only way to really mix audio is the software keyer. Here the audio is read, mixed in software and written out. So we should find out why that's not working.
-- Dierk Ohlerich
OK, my bad! Had a recollection of me mixing audio in the HW keyer mode, but apparently it was made in SW keyer mode.
Anyway, for some reason the scene doesn't render in SW keyer mode. can I send you a .vpa too see if something in the scene prevents it from rendering, the machine used for this is a VBOX, not the latest ones, but anyway, I don't think it has to do with performance?
// Sam
// Sam
- Dierk Ohlerich
The next Ventuz Version - 4.03.03 or 4.04.00 - will contain a bugfix solving this problem with the software keying.
-- Dierk Ohlerich
