Setup:
- Windows 7 Professional 64bit
- Ventuzversion: 4.02.00.715
- 2 PCs with Firepro V7900 + S400 + Blackmagic Syncgenerator
- Each PC has 2 times 1920 x 1200 with 50Hz as Eyefinity Gruppe (2 x 3840x1200)
- Clusterclock + Swap Sync
- Housesync on PC 1
- PC 1: ID 1 Group 1
- PC 2: ID 2 Group 1
- Catalyst Version 13.152
- Housesync tested with 576i50 / 1080i50 / 720p50
- Per RJ45 to PC 2
- Result: Renderer keeps black or bluescreen. Ventuz 3 works fine. Without swap sync Ventuz 4 works too, but of course with flickering cluster clock.
- Instead of Housesync using output one on PC1 as timing server
- Per RJ45 to PC 2
- Catalyst Version 9.003.3
- Per RJ45 to PC 2
- Result: Renderer runs, but with heavy flickering cluster clock what means for me that the swap sync isn't running fine. Ventuz 3 shows a constant green cluster clock.
- Per RJ45 to PC 2
- Catalyst Version 12.104.2
- Per RJ45 to PC 2
- Result: This Catalyst version don´t allows me to activate the house sync
- Per RJ45 to PC 2
- Result: Renderer runs with a constant green cluster clock, but only with 25fps. Ventuz 3 runs at 50 fps and a constant green cluster clock.
- Catalyst Version 13.25.18.1 Beta
- Per RJ45 to PC 2
- Result: Graphic adapter crashs. PC needs a hard reset. Ventuz 3 works fine. Without swapsync Ventuz 4 works too, but of course with flickering cluster clock.
- Catalyst Version13.25.18.1 Beta
- Per RJ45 to PC 2
By the way I got the same results with other PCs (Windows 8, W7000) too.
Thx
Sven
