Ventuz with Watchout
Posted: 21 Oct 2013, 08:34
by progenix
I am currently trying to display a Ventuz output resolution of 3840X1080 from an ATI Card using 2 DVIs. I am using Watchout to do the blending on 2 HD projectors. The watchout servers are using 2 capture cards that can only accept 1920x1080 each. However, there was noticeable sync and tearing after we blend them together. Any solutions to this?
Re: Ventuz with Watchout
Posted: 22 Oct 2013, 19:27
hi progenix
what a setup......first of all: why are you using a realtime software to feed a media server?
what grafics card are you using? if it is a consumer card, it could be, that both outputs are not frame synched!
which grabber gards are you using...is it a genlocked setup?
tearing: on one output or do you mean delay between both projectors?
if you are using a pro card like the firepro i would think your problem is related to watchout!
Posted: 22 Oct 2013, 23:56
by joysprod
If you are only using Watchout to do the blend, personally I would use Ventuz to produce the overlap but choose a projector that has blending built in.
Posted: 23 Oct 2013, 07:04
by Christian Krix Schmidt
Totally agree with Peter. Ditch Watchout. Using Watchout simply for edge blending is a budget killer and is actually more limiting than creating the overlap in Ventuz.
Posted: 26 Oct 2013, 18:02
by ErikB
Our new Edge Blending, Warping and Shaping toolset for V4 is almost ready as well!
Posted: 30 Oct 2013, 09:47
by progen
Hi ErikB,
Any timeline on when these new tools for V4 will be out? I am current using V3. Will the tools in suffice for now?
Charles
Posted: 30 Oct 2013, 15:42
We are still using V3 as well. The EdgeBlending in V3 is not the best but does a decent job. But if you do that with the projectors there is nothing stopping you to use Ventuz for the rest.
Posted: 30 Oct 2013, 18:32
by ErikB
New tools for Shaping and Blending should be in the next point release, hopefully. (so 4.02). Let's say with the way things look right now, it should be a very early Xmas present. Of course we cannot be 100% sure, as things can always go wrong, but so far initial feedback is excellent.
-E
Posted: 02 May 2015, 07:24
by calonpintar
i'm also both ventuz & watchout user,
- did you test your ventuz 2 output directly to 2 monitors? is the video sync'd up?
- if yes, it is probably you have problem with your capture card?
it is better if we don't mixed up between this 2 software especially with synchronized video capture,
if you have less video playback (e.g. 5 videos) it is very easy to bring that files to ventuz node.
if we are talking about projection mapping and output mesh warping, ventuz 4 new tool will handle it easily.
