ODBC Database freeze animations
Maecki
Post by Maecki » 04 Apr 2016, 13:48
Hi All,
I have a problem with ODBC Database and Animations in Ventuz.
While Ventuz read Database Values (I use the Query Note and hit the Execute), Animations in Ventuz will freeze.
If all Data will be in, the animation goes on. Also the same problem with a crawl/ticker.
Have somebody a solution/ idea ? :idea:
Greetz and thanks from Bonn//Marcel
SamTheSwede
Re: ODBC Database freeze animations
Post by SamTheSwede » 04 Apr 2016, 14:08
Did you check the "Asynchron" box?
I'm not using the db-nodes myself, but executing Querys is usually best done in an async call.
/ Sam
Maecki
Post by Maecki » 04 Apr 2016, 17:24
Hi Sam,
thanks for the solution. It works fine...!!!
Greetz//Marcel
