AMD Eyefinitygroup cluster building problem
stephan
Post by stephan » 30 Jan 2016, 18:51
Dear community,
I never had problems in cluster building in the past. But from now on ...
Building a fresh win7 system (updated till end of 2015), graphicscard AMD W8100, last firepro-drivers, eyefinitygroup (3x1920)x1080.
Everything's fine.
The Ventuz-Configmanager (v.4.07.01) don't accept this eyefinitygroup and shows the attached errors
( ... one ore more elements in the cluster have a zero resolution ???)
The created layout is 1x 1920x1080.
I have no idea what to do ...
thanks in advance for your help,
Stephan
error pop-up
stephan
Re: AMD Eyefinitygroup cluster building problem
Post by stephan » 30 Jan 2016, 20:08
... forgot to say, can't create the following render-setup because of hang-up (freeze) :shock:
stephan
Post by stephan » 31 Jan 2016, 10:23
Problem solved, but unknown reason for mailfunction ...
Building an identical system this night, same hardware except the graphicscard (W9100), and it's ok :!:
The Configurator works as expected, can build displaygroups.
Very strange, I can't explain myself ... it must be a hardware problem, Ventuz is innocent :)
Stephan
stephan
Post by stephan » 01 Feb 2016, 09:16
... the mainboard is the killer :shock:
Both systems uses absolutely identical asus mb's, one system works, the other not.
It's better to give up any search for a reason :)
Stephan
lerou
Post by lerou » 01 Feb 2016, 09:44
I just set up a test cluster with an Eyefinity group - used consumer GPUs though. Same issue: Ventuz Config couldn't retrieve the info from the system. I just set it up manually and it works. The error pretty much only means your system doesn't report the display config correctly for some reason. I wouldn't assume any hardware error. Although I don't know about your freezing issue.
Best,
Post by Karol » 01 Feb 2016, 10:59
Lerou is right!
This error message only means that Ventuz Machine Service (VMS) could not retrieve any valid display setup information from the graphics board (could be related to the driver version or a bug on our side).
In such a case you have to build your RenderSetup manually.
BUT this does NOT affect the functionality of the RenderSetup rendering in Ventuz. This automatic RenderSetup build is only a convenience feature. :)
stephan
Post by stephan » 01 Feb 2016, 12:34
Thanks guys for answering,
the problem is freezing after closing the popup-menu, so I could'nt setup render-settings >CTRL-ALT-DELETE ... :)
Stephan
lerou
Post by lerou » 01 Feb 2016, 12:37
Now that's something for the Bug-Forum ;)
stephan
Post by stephan » 01 Feb 2016, 13:22
that's something for the recycling-hof :D
