keystone
keystone
Post by chriss0212 » 11 Oct 2014, 17:23
hi all.....
we developed a simple module to make a keystone corection inside of ventuz ;)
https://www.hightail.com/download/UlRUe ... NVZjR05Vag
Götz_B
Re: keystone
Post by Götz_B » 04 Nov 2014, 17:13
Hey!
What do you use it for? Are you not satisfied with the Shaping Tool or do you use it dynamically in the scene .... ?
Or just because you can ? ;)
Re: keystone
Post by chriss0212 » 05 Nov 2014, 19:27
hi götz...
yes we can ;)
.....no....first of all: havent checked, if i ventuz shaping can do keystoning with automatic correction of the homographic distortions?!
next: i dont need a render target for this setup...i am correcting the camera matrix!
Re: keystone
Post by chriss0212 » 06 Nov 2014, 12:51
hi götz
what i am doing with our tool....you have to compare with the 3d projection settings in the shaper. i would say, that our tool is more efficient and faster in calibrating because i have just to move the 4 corner points and all camera settings are calibrated.
Wuzzi
Re: keystone
Post by Wuzzi » 25 Apr 2019, 13:44
Nice Job!
could you give an example or a little hint how you solved this? :-)
