Movie Clip advanced Autoplay bug
Robert
Post by Robert » 13 Apr 2013, 22:41
I ran into this bug with the Movie Clip Advanced in autoplay mode.
1. Playback a vdeo using the enable property in autoplay mode. Let it play until it reach the end of the file.
2. Disable the Node
3. Enable it again to try to playback the video and it doesn't work.
R
Re: Movie Clip advanced Autoplay bug
Post by chriss0212 » 17 Apr 2013, 20:17
havn't tried it but doesn't sound like a bug...you disable the video after it has played to the end...after reenabling it should be still at the end so you have to seek to 0 to start it again
Robert
Post by Robert » 18 Apr 2013, 13:38
Christian,
Ok, but why do the video restart from the beginning when I previously disabled it à 50% of the duration then ?
This is misleading.
Robert
Post by chriss0212 » 02 May 2013, 06:36
ok....good question ;)
what you could try is: bind the enabel with an event to the search input. maybe the even need to have a delay! and of course you need to change the movie node to auto play after seek!
just a workaround but could help!
