.NET Remoting and Callbacks
hummerbaendiger
Post by hummerbaendiger » 22 Mar 2012, 16:01
I'm currently working with the .NET remoting interface in an external C# program.
Can anyone give me a short sample on how to use the callback functions to connect functions of an external program to events invoked by Ventuz?
I knew this already was here somewhere in the forum, but I can't find it anymore.
Thank you!
Re: .NET Remoting and Callbacks
Post by Karol » 27 Mar 2012, 09:07
Hi!
With Ventuz Remoting 2 it would look like this:
private void SetupEvents(IExternalCollection extColl)
        if ( extColl != null )
                // get Event names for subscribtion
                IEnumerator<IExternal> extEnum = extColl.GetEnumerator();
                while ( extEnum.MoveNext() )
                    IExternal ext = extEnum.Current;
                    // subscribe to externalized events
                    if ( ext is IExternalEvent )
                        ((IExternalEvent)ext).Callback += new ExternalEventHandler(Event_Callback);
                        Console.WriteLine("-- Subscribed to Event {0}", ((IExternalEvent)ext).Name);
Use the Externals property on your RemoteScene instance to get the IExternalCollection.
See the Ventuz Remoting API Help for further details.
divingeon
Post by divingeon » 18 Apr 2014, 09:46
hi, Karol
While I was finding "CallBack" on this forum, I found your post.
btw,
What is the "Event_Callback" above this code?
How can I Make it?
thanks
divin
Post by Karol » 22 Apr 2014, 09:31
Hi!
'Event_Callback' is the callback method which is called if an event occurs :
Could be something like this:
        private void Event_Callback(IExternalEvent exernal, ulong time, int arg)
            Console.WriteLine("-=# EVENT_CALLBACK #=-");
            lock ( this.eventQ )
                // fill Q. to process it in UpdateEvents()
                this.eventQ.Enqueue(string.Format("Event #{0}: {1} - Args = {2}\r\n", ++evCount, exernal.Name, arg));
                this.haveNewEvents = true;
            if ( this.tbEvents.InvokeRequired )
                // cross-thread: so invoke on GUI-Thread
                this.tbEvents.Invoke(new UpdateEventText(this.UpdateEvents));
            else
                this.UpdateEvents();
divingeon
Post by divingeon » 23 Apr 2014, 03:11
thanks a lot :)
