dmx tutorial
gabrielefx
dmx tutorial
Post by gabrielefx » 29 Apr 2013, 09:33
Hi all
I don't remember if the Express edition supports dmx output.
Does exist a tutorial on how create simple switches to control on-off and dimmer dmx lights?
I use the Sunlite 2 software, it has an usb interface, is it ok for Ventuz?
I have another option, I'm buying this interface: http://www.thomann.de/it/ma_lighting2port_node_onpc.htm
I don't know if the MA port node is compatible with your software.
Oliver
Re: dmx tutorial
Post by Oliver » 29 Apr 2013, 16:16
should work with professional edition :P
TobiTobsen
Re: dmx tutorial
Post by TobiTobsen » 29 Apr 2013, 20:09
http://www.radar-touch.com
http://www.prime-touch.com
Re: dmx tutorial
Post by chriss0212 » 30 Apr 2013, 18:32
but he still needs the pro version!
you could try something like this:
http://www.cinetix.de/interface/midmxbox.htm
this is a converter from midi to dmx!
or a software like this:
http://www.lightjams.com/midiDMX.html
gabrielefx
Re: dmx tutorial
Post by gabrielefx » 03 May 2013, 00:00
thank you!
I would like to buy the pro version.
