how to view the previous and next slides during slide...?
alfred
Post by alfred » 11 Mar 2013, 13:32
I have four slides, inside SlideManager, I hope the previous and next slides are also visible during slide transitions, how to set? Set the visible mode of the slide manager options as “current and neighbors” is enough? Or do I need change other settings? In turtorial, it is said that I need to "assigning a NEGATIVE value to EaseIn", but I do not find how to set the value to be a NEGATIVE, I can only change the numbers.
I have changed the settings of visible mode from "current and neighbours" to "all" and "current only", but nothing has been changed.
alfred
Robert
Re: how to view the previous and next slides during slide...
Post by Robert » 11 Mar 2013, 22:05
Alfred,
You can only see one presented state of one slide at one time. If you set the visible mode to current and neighbours, you should be able to see the end state of previous slide and the begin state of next slide. Others slides will be blocked.
Be carefull, setting the alpha value at zero at the begining and at the end of the slide animation make those next and previous slides invisible anyway.
Robert
