red some threads about it but didn´t find an answer.
ok - I tried to import some objects into Ventuz from C4d as .obj´s.
But the objects pivots are always in 000 after have been imported into Ventuz.
I noticed that in a axis-node you can modify the pivot. Question - is it necessary to manipulate the pivot manually (in axis-node) in order to bring each objects pivot into it´s center?
Marko
Importing an 3d object - Pivot is always in 000
Re: Importing an 3d object - Pivot is always in 000
The problem is a limitation of OBJ file format. It does not store the pivot information. You have to use another format. Collada DAE will work fine.
One of the reasons we always recommend to work with .dae
