hi,
I have a scene with a kind of star..let's says spheres orbiting around a main sphere through "touch orbit" node.
I want to trigger an action when I click on one of the spheres with "touch button" node.
however when I have the orbit as a top layer in the scene hiearchy, The touch button doesn;t catch the user input. if I desactivate my orbit node then it works.
How to solve this?
thanks
multiple interaction layers
Re: multiple interaction layers
Hi
You could use a TouchExluder node to stop the intersection test of the TouchOrbit node a certain point in the hierarchy.
If you combine the Touch nodes the right way you could solve it without a TouchExluder, take a look at the dynamic Helpscene of the ArrayIndexer (press F1 on the node) there is a quite nice example under the ArrayAdvanced tab.
Cherio!
Cherio!
here is my file. when I press on a selected text the rectangle shall disapear...
- heart effect 2.vzs
- (49.59 KiB) Downloaded 484 times
Hi renaudbarbier,
you've got problems with the Touch Events in fact of a wrong Z-order. Your Touch mesh is in Z-order behind an other effect object. So it can't work.
I recommend you to use a ZSort node for your Interface to prevent other optical Z problems. Click F1 on the ZSort node, read the user manual entry und have a look at the given help scene example there!
I also fix that problem for one example element in your scene. Under "File"- "Import" you can load the *.vza example file.
Regards,
Stefan
Regards,
Stefan
- Z_Touch_Support.vza
- (53.44 KiB) Downloaded 538 times
