Screensaver
Screensaver
how do you know that the application is not used for a while time, and go to the welcome page (screensaver), for example
Re: Screensaver
you could use OSC out nodes at each of your interactive elements. Those could trigger one OSC in and reset a timer. if the timer reaches its end, you could start your screensaver etc.
cheers!
cheers!
http://www.radar-touch.com
http://www.prime-touch.com
Re: Screensaver
hi LanzeTe
osc is one solution...but you could also send a keystroke on any input event...for eg pageDown....and every time you get the pageDown key you start a timer in reversed direction...and if the timer reach its end...maybe at 30 seconds...you start your screensaver animation
