hi all,
what is the best way to setup a rectangle to automatically adjust it aspect ratio when using the video node but keeping the overall scale factor to 1 ?
Aspect Ratio
Re: Aspect Ratio
Hi Hashim,
use the Normalize function of the Rectangle node. It is described in the documentation.
Re: Aspect Ratio
Just because this is a cool trick and people seem to miss it in the documentation, for some reason:Karol wrote:Hi Hashim,
Use a rectangle, connect the X size of the rectangle node to the Width of the Video node, Y to the Height, then tick normalize. That way, it will automatically be the correct aspect ratio, depending on whatever Video is currently loaded, but normalized to 1.
