Hi there,
When I try to make Render to Disk of my project in order to show a preview to our clients, I can't make it right. Never.
Here is my walkthrough: I open the scene, and a new one, just to make sure that all my Scene event nodes are triggered by switching from one tab to another. I hit the Start Capture button, and I make the demo. I switch back to the scene so the Scene events are triggered and everything is on the same place. And then, no matter if I click the "Play Interaction" or the "Render to disk" buttons, everything go anyway but the way I captured it.
My current shortcut is to record the screen with Camtasia Recorder, but the results are far from good. Pretty quirky and not smooth at all.
What am I doing wrong? Is there a way to set up the scene so the Render to Disk capture is what I want it to be?
Thank you in advance!
How to make a proper Render to Disk?
Re: How to make a proper Render to Disk?
I've tested a couple of different scenarios and the RendertoDisk module is working as expected.
I guess you read the RenderToDisk Usermanual page and noticed that in Interactive mode only the interaction with the Renderer is recorded and not the interaction with the Designer GUI (e.g. Property Editor)!
If you still have problems feel free to ask.
Cheers!
Daniel
Cheers!
Daniel
