Touch Marker compatible devices
gabrielefx
I would like to know what's the best (and cheap) device compatible with the touch marker feature.
Does exist a capacitive multitouch monitor with this embedded technology?
Is the Samsung SUR40 compatible?
Re: Touch Marker compatible devices
hi gabriel
if you are looking for a display solution...the only devices i know...and works ok....are the multitaction displays! forget the samsung!
we are working on a system...but this is realy not easy and we are far away from good results ;(
gabrielefx
Thank you!
I hope that Multitaction displays don't need scripts to work with Ventuz...
Luckily no. You really just have to use the Touch Marker node and the other touch interaction nodes. Works very well.
We just cooperated with Multitaction on their booth at Infocomm, and had them on our booth at NAB. They work excellently, and setting up markers is really, really easy.
-E
-E
alfred
Instead of Multitaction, is there any brand which is compatible with Ventuz for touch marker?
Cheers!
alfred
Cheers!
alfred
...or you build your own, have a look:
http://nuigroup.com/forums/
overview about the different technics:
http://nuigroup.com/forums/viewthread/1982/
for markers you need the rear DI..
joschy
joschy
alfred
Hey Joschy,
It is really a good forum to get to know touch techniques, but I have no enough resources to DIY. So I will appreciate your help if you have some other recommendations.
br
alfred
br
alfred
gabrielefx
