is there a way to use static class and variable with the c# script node in Ventuz.
I try to instanciate a cluster variable in a c# script node
then access this variable between severals c# script node in my project.
Is this possible ?
Mat.
C# script : STATIC class
Re: C# script : STATIC class
Hi Mat,
unfortunately this is not possible.
You can try to output variables from others scripts and inject them into main script.
But it will be simplest to regroup everything into a same script.
