effect FX-Node/ white lines on image
Posted: 05 Sep 2017, 15:54
I've got a problem with the effect FX-Node.
I wanted to animate the blur-effect between two movies and changed the values for diameter and aspect.
At some values, you will get fine white lines on the texture. I added an image of the result.
The problem occurs on different pc's.
Greetings
Mathias
Greetings
Mathias
