I'm using Ventuz 4 with a Decklink 4k Pro card and having problems getting a key output.
I only get two fills from the card, the 4k Pro shouldn't be that different to a 4k Extreme card what I understand.
Someone else having this issue?
I tried running CasparCG on the same machine and it works with Fill & Key when using the same settings as from a machine with 4k Extreme card.
I'm running version 10.9.5.0 of the Decklink driver.
Decklink 4k Pro with Fill & Key problem
Re: Decklink 4k Pro with Fill & Key problem
Found the problem, forgot to set Mode to external keying...... To many days with long hours that for sure......
