Hi All,
I have created a basic form to collect some text and save it out in CSV format.
I'm not the best in the world at scripting......so would someone mind having a quick look over my scene and letting me know if I can improve the script
in any way??
Is this the most efficient way to create as CSV file in Ventuz?
I also wanted to force some rules for the text that is entered in the boxes, i.e. not allowing the text to be added to the file unless a valid email address is entered.
Would anyone know how I can accomplish this??
The scene is pretty basic at this point, but any other suggestions on the scene as a whole are also more than welcome
Chris
Save text to CSV file
- Text to CSV.vza
- (34.39 KiB) Downloaded 273 times
Re: Save text to CSV file
may be you already found this: https://social.msdn.microsoft.com/Forum ... m=netfxbcl
I can't load your file currently, it's PLE. Don't know how large your file is and there is a for loop, you should use the thread class https://msdn.microsoft.com/en-us/librar ... 71%29.aspx
Hey,
Thanks for the reply joschy
Here's my code
It all works fine, just wondering if there is anything I should change to make it better??
Chris
Here's my code
//if file doesnt exist, create file
if (!File.Exists(filePath))
File.Create(filePath).Close();
// Append line to the file.
using (StreamWriter writer = new StreamWriter(filePath, true))
writer.WriteLine(Data);
changed = true;
Chris
