Image from URL
Image from URL
Hi everyone. I'm trying to pull in an image from an XML feed, but having a difficult time using the URL node to do this. The XML feed comes in via HTTP, and is constantly updated. Any suggestions?
Re: Image from URL
fetch the xml, select the image url and use it in a texture loader. You can select nodes/attributes from the xml using Ventuz xml nodes or you write a little script.
The example shows both - in a very! basic way.
Best,
Best,
- web_xml.vza
- (29.42 KiB) Downloaded 262 times
