I am an amateur in using ventuz. Though i have a little knowledge of working with the designer but i am still struggling with the director.
I have made a scene where a button would trigger an vdo to play but as soon as i cue it in the director it shows no interaction the i had applied.
Can you suggest as to how should i proceed for the desired result.
Best regards,
Anupama
Using Interactive Projects
Re: Using Interactive Projects
Hi there
The Director Preview and Program windows are not interactive, they will becomme in the future but aren't right now.
The interaction usually is done on the ouput (SDI,DVI...) The Director just grabs a preview of that output but is not generating any interaction data and send it to the runtime.
If you want buttons or values to be available from director you have to add the properties to either ProjectData, SceneData or AnimationData.
You can find some HowTos about Templates in the usermanual
Regards Daniel
Regards Daniel
