how to full screen with Ventuz Presenter?
Is that possible?
I want to see full screen image without the gray frame around it.
Thanks friends
How to Ventuz Presenter full screen?
Re: How to Ventuz Presenter full screen?
Your project settings need to be the same resolution and/or aspect ratio as the one of your output display. If the aspect ratio is not the same, Ventuz will add bars. You can change the color of the bars in the Direct3D settings of the project properties. Alternatively you can deactivate "Keep Aspect" in the Direct3D settings under Fullscreen. Then Ventuz will match the aspect ratio to your screen resolution. But if your scene is not set up for this you might see wrong graphics on the side or objects that are not faded out, etc.
You can switch between fullscreen and windowed mode of the presenter by pressing ALT + ENTER. Or make sure that the Startup mode in the Windows settings of the project properties is set to Fullscreen. Then the VPR you export will start fullscreen automatically.
Thanks Christian Krix Schmidt.
I've tried it and it works. but the problem I have with the broadcast Presenter version
You can force the Presenter to start in professional version.
Just make a shortcut of your Presenter.exe and add the commandline option "-pro".
Check the Command Line Options Usermanual page. for futher information.
Cheers!
Cheers!
