A lot of data (using excel)
Roman
Post by Roman » 22 Nov 2017, 18:12
Hi! We often work with large amounts of data in Excel. And we need to dynamically change the pointers to workbook cells. But changing causes content validation surge and program lags. Can you give us some advice of how to work with external data in general?
Thank you!
Roman
Re: A lot of data (using excel)
Post by Roman » 20 Dec 2017, 17:26
Any suggestions?
Post by Christian Krix Schmidt » 23 Dec 2017, 08:16
You could read from the Excel file yourself from within a C# node. I think if you use async file reading and parsing operations it should be possible to avoid the spikes you encounter. Maybe this helps: https://coderwall.com/p/app3ya/read-excel-file-in-c
Roman
Post by Roman » 30 Dec 2017, 15:47
Thank you! We will try.
