empty timeline in animation, unable to navigate to zero
Postby stephan » 03 Feb 2017, 17:13
My animation-timeline was well filled and cursor placed nearly high numbers (20.000).
After switching between my workspace-layouts and re-opening animation-timeline, timeline was empty without any layer and I can't navigate to zero.
After switching several times between my windows, saving project under new name and re-opening, suddenly Ventuz repairs itself :D
it appears last week in v5.02.01 (I didn't want to update within my job), unfortunately I can't reproduce this error.
Stephan
stephan
Re: empty timeline in animation, unable to navigate to zero
Postby Etienne » 04 Feb 2017, 21:40
In the Animation TimeView windows you can use the mouse's scrollwheel to control the scale of the timeline. Also, there's a scrollbar that appears at the bottom of the window, under the time/frame markers. You should be able to use both of these methods to get to where you want to go in your timeline.
Etienne
Postby stephan » 05 Feb 2017, 19:00
You are right Etienne,
under normal conditions, yes.
But exactly this was my problem, mouse-navigation didn't work!
Many greet,
Stephan
stephan
Postby stephan » 05 Feb 2017, 19:01
... and also not scrollbar ...
stephan
Postby Dennis » 06 Feb 2017, 11:17
Hi Stephan,
afaik we did not touch the Animation Editor within the releases, but when you finished your job, could you please update and check if the error persists?
You said you can not reproduce this behavior? So it was just the one time the case and works now?
If not: could you please provide the scene with the 20000 frames animation and send it over to us?
thank you very much
regArts
:ugeek:
Postby stephan » 06 Feb 2017, 12:30
Thanks Dennis,
I'm trying to reproduce this error with 5.02.02,
please wait until tomorrow ...
Greets, Stephan
stephan
Postby stephan » 08 Feb 2017, 12:10
I'm unable to reproduce this error Dennis.
Perhaps a temporarly windows issue. :D
Stephan
stephan
Return to Bug Reports
cron
