the obj importer seems to be completely broken in V5. It seems to import each face separately for pretty much all geometry I've used :/ Could you have a look at that?!
OBJ Importer
Re: OBJ Importer
Hi rou!
What exactly do you mean with "import each face separately"?
Re: OBJ Importer
Well, it seems the default behaviour is that the object is split by the material. Now many exporters add a lot of redundant information into the obj file. Like this:
now if you drag that into Ventuz, each face will become one geometry instead of just having one. The example above should never be interpreted as many subsets as it is the same material every time.
However I was able to get the desired result by changing the parameters. So I guess it's not really broken, just a bit cumbersome to use.
Nervermind, for now I withdraw this bug report until I got time to play with the importer a bit more.
usemtl scene_material1
f 59//241 61//242 62//243 60//244
f 59//245 60//246 64//247 63//248
f 59//249 63//250 65//251 61//252
f 60//253 62//254 66//255 64//256
Re: OBJ Importer
Hey rou..
i was on the road and had no 3D tool with me.
Therefore i tried to import a MODO FBX and it didnt work as well.. just an scale axis popped onto my scene.
While i had Visual Studio on the Laptop i could import the FBX easy, and export it as OBJ. The import went perfectly fine.
i will recheck this "old" but still used OBJ as well as the FBX from different tools.
since i asked _Gizmo thousand times to send me some more files to countercheck again again and again.. and i didnt recieve any.. i wasnt able to test this properly under "working circumstances"...
please push him as well to send me more refs....
would be greaaaat!!!
Re: OBJ Importer
well, main problem I have at the moment (need to work with it some more) is the default behaviour. Basically with V4 you had the (annoying) import dialog. The good thing about it: it remembered your settings. So once you had it set up correctly, you could just import one model after the other. Now with drag&drop I believe it uses the defaults each time and having to set the correct settings after each import might be a hassle.
I'll export an obj for you once I find the time.
cheers,
cheers,
Re: OBJ Importer
Hi rou,
yes if you find a model which doesnt work as expected forward this one..
as well as the software which you used to export ... exact obj exporter as well...
i remember that the "inbuild" OBJ exporter for 3dsmax made some trouble, therefore i used the open collada one.
i had an issue some days ago with modo and the FBX from modo.. sadly i had no chance to check the modo version etc.. all i got imported was a single "scale axis", nothing more.
i will ask the client for the exact combination for the modo and exporter version, maybe i can replicate this failed import.
Why i pointed out _gizmo in this case:
He is one of the guys i know, who is using kinda "exotic software" like softimage and other tools which we dont have access to, to check all the import routines,...
Yes we need support and feedback from all of you guys, so that no trouble occurs while in the design or import process...
Best RegArts
Best RegArts
Re: OBJ Importer
Well... let's not forget we're talking about obj here. It's not exactly the most complex format there is. The problem I spoke about shouldn't be one, even without your customers providing test cases for you. Actually, what I posted above should be enough. You can write a simple obj in a text editor. Buuuuut, I'll be so nice and provide a sample
