Perlin vertex noise on points - Bug
Naggar
Post by Naggar » 19 Apr 2018, 12:30
Hi I have an issue When creating Points with vertex noise and perlin vertex noise and Its definitely a bug.
So when I add perlin vertex noise to a material followed by points options (Sprite on), and points.. it doesn't work..
However sometimes when I change seed of points or change radius or hole, it would work and only at some seeds, and only affecting some points. But if I save and close scene, this stops working when I open the scene. as if Perlin vertex noise is inactive in the material.. Activating and inactivating makes only a difference in highlights sometimes, but points are in same places. Same thing with changing ScaleUV in the properties.. only affects ligthing.
Re: Perlin vertex noise on points - Bug
Post by Karol » 19 Apr 2018, 12:55
can you please post a simple demo scene?
Naggar
Post by Naggar » 26 Apr 2018, 08:37
Hi
I've attached a simple demo with a switcher between only vertex noise and another with perlin vertex noise.. you will find that there is no difference between both as long as points node have same seeds
Demo Perlin Vertex noise.vza
(13.03 KiB) Downloaded 273 times
