Layout node - AlignmentY support
Postby gaz99 » 15 Jun 2017, 14:42
Currently as per the Ventuz 5 Help notes the Layout Node only supports the Alignment X with an arranger.
For the Layout controller to work, the Arrange node has to be set to LeftChain (Left-To-Right reading) or RightChain (Right-To-Left reading) for AlignmentX. Other layouts are not supported yet. AlignmentY and AlignmentZ are ignored.
Could we have support for the Layout node to work with AlignmentY. This would be a great help.
Gaz
Gareth - Kinetic Pixel
gaz99
Re: Layout node - AlignmentY support
Postby gaz99 » 14 Aug 2017, 09:37
Is there any update on getting this functionality? Currently I am looking into a way around this using a script but it would be so much simpler if we could have support for the Alignment Y as setting properties via XML attributes is really useful.
Gaz
gaz99
Postby gaz99 » 17 Nov 2017, 10:35
Bump
gaz99
Return to Feature Requests
