Importing 3D models animation to ventuz
ahmedahmed1223
Post by ahmedahmed1223 » 15 Sep 2017, 08:36
Hi there,
what is the common way to import 3d model animation with its material to ventuz 5 other than c4d live link method?
because i have tried a lot of scenarios and all failed like exported fbx,dae, obj sequence etc..
thanks for helping :D
ahmedahmed1223
Re: Importing 3D models animation to ventuz
Post by ahmedahmed1223 » 17 Sep 2017, 13:06
Is there any ideas?
it seems this is complicated subject i think :?:
ahmedahmed1223
Post by ahmedahmed1223 » 21 Sep 2017, 13:35
Post by Karol » 21 Sep 2017, 13:54
This forum has a search function!
Gives e.g.: http://forum.ventuz.com/viewtopic.php?f=43&t=4173
ahmedahmed1223
Post by ahmedahmed1223 » 21 Sep 2017, 16:32
Thanks Karol,
i need to import animation to ventuz 5 not ventuz 4,and the topic you mentioned is an old topic. :!:
so is the current ventuz 5 software can import 3d object animations by itself?
if it cants what is the other solutions to do that in ventuz5 ? :?:
Post by Dennis » 22 Sep 2017, 08:57
Hey Ahmed,
we had this discussion already and also mentioned that the animation import has to be done by using ventuz 4 (as joe styles mentioned in an earlier post where you asked about the camera import).
The post from karol referred to the procedure how to get animations into V5.
You would need a licensed copy of ventuz 4&5 by the way ;) ;) ;) or you would need to go with both PLE versions....
regArts
:ugeek:
ahmedahmed1223
Post by ahmedahmed1223 » 22 Sep 2017, 11:19
Hi Dennis,
i know if something broken in any software it needed to be fixed as soon as possible ,
i think there is a real problems in ventuz 5 importing 3d files workflow it have been more than year for this problem and there is no real fix for that. :!:
best rgards
ahmed
Post by Dennis » 22 Sep 2017, 13:21
ahmedahmed1223 wrote:Hi Dennis,
best rgards
ahmed
Since the beginning we have informed about the WORKAROUND.
All the best
and regArts
:ugeek:
