How to custom Presenter startup UI?
yeyoumo
Post by yeyoumo » 19 Jul 2017, 11:11
Hi, all:
How to custom Presenter startup UI? Instead of orange square.
yeyoumo
Re: How to custom Presenter startup UI?
Post by yeyoumo » 20 Jul 2017, 11:00
yeyoumo wrote:Hi, all:
How to custom
Machine Configuration->EXTENDED->Progress Visualization Settings->Progress Type?
Post by Dennis » 20 Jul 2017, 12:30
Yes there you can change the "orange sqaures (for a single Runtime machine).
As you can see by the "Color encoded by machine id" .. in a cluster setup, each machine will use a slightly different color when the cluster runtime boots up.
Turn it to "none" and you will not see any squares or whatever :)
yeyoumo
Post by yeyoumo » 21 Jul 2017, 04:18
But I want to custom the progress type, for example, I want to load my customized startup animation when .vpr is opening.
Post by Karol » 21 Jul 2017, 09:13
You can build your own loaded scene (but it should be small and load fast).
This loader scene needs to have a Scene Port to load the actual scene and must be configured as a 'Layout Scene' in the Project Properties.
yeyoumo
Post by yeyoumo » 24 Jul 2017, 11:37
Thanks Karol!!
Can you give me some more details, such as some pictures or anything else? I am a beginner of ventuz... :?
