extrude along path
extrude along path
I'm just creating a globe/map animation and want to trace a path from one location to the next, similar to an aircraft flight. I thought that I would extrude a shape along a path for this. Is that possible? or have you alternative ideas...?
Re: extrude along path
why not use a circle with a hole? Might be a little clunky to position and scale.
cheers
cheers
In such cases i would use a 3d-modeler and extrude along a spline...
Use a gradient and move the texture
