Hi ventuz community !
I wanted to know if there is a way to see textures wheight like we see it in the Movie clip node?
Texture wheight
Re: Texture wheight
Do you mean the texture's size in CPU/GPU memory? Check out Scene/Scene statistics and select Resources. You'll find your assets there and it will tell you the sizes.
For textures it's relatively simple do calulcate: PNGs and JPGs usually take up w x h x 4 Bytes. So a 1024x1024 texure is 4MB. DDS are not decompressed, so they pretty much need the same GPU memory as their file size.
Best,
Best,
