Hi, I have been writing all my ventuz remoting applications using only Ventuz OSC (not using remoting 4) because I couldn't understand the remoting 4 demo programs posted in earlier posts...
All I need is a clear, well commented demo of a very simple program using c# winforms please (not console or wincp, xaml....), to discover the machines connected and list them in a listbox,load a scene (any static file) to the machine selected in the list, and send few data (2-3 textboxes will do).
The Remoting 4 demo is really very complicated for me to start with, even the small one.
Thank you very much.
Remoting 4
Re: Remoting 4
Please I'm stuck, i really appreciate any help. Ventuz Runtime loads the project, but I don't know how to load the scene to it . . . i'm really frustrated .... here is the code I have so far... (and I don't want to use clusters if possible)
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
using Ventuz.Remoting4;
using Ventuz.Remoting4.MachineService;
using System.Net;
namespace WindowsFormsApplication1
public partial class Form1 : Form
Cluster servercluster;
Cluster cluster = null;
VMSClient theclients;
List<VMS> AllVMachines = new List<VMS>();
List<VMSClient> activeVMSClients = new List<VMSClient>();
public Form1()
InitializeComponent();
private void button1_Click(object sender, EventArgs e)
var theclient = new VMSDiscovery(5, 0, null);
label2.Text = VMSDiscovery.GetLocalSystemId();
label1.Text = theclient.ToString();
StartMachineDiscovery();
VMSDiscovery vmsDiscover = null;
private void StartMachineDiscovery()
if (this.vmsDiscover == null)
this.vmsDiscover = new VMSDiscovery(10);
this.vmsDiscover.PropertyChanged += VMSDiscovery_Changed;
this.vmsDiscover.Discover();
else
private void VMSDiscovery_Changed(object sender, PropertyChangedEventArgs e)
// TODO: compare with existing?
// create list from discovered Ventuz machines
AllVMachines = new List<VMS>(vmsDiscover.Items);
private void button2_Click(object sender, EventArgs e)
this.cluster = new Cluster { Name = "Wall" };
foreach (VMS vms in this.AllVMachines)
var aa = vms.ID;
var bb = vms.IPAddress;
var cc = vms.IPEndPoint;
//this.cluster.AddMachine(new IPEndPoint(vms.IPAddress, Cluster.DEFAULT_PORT));
this.activeVMSClients.Add(new VMSClient(vms));
this.cluster.AddMachine(cc);
listBox1.Items.Add(aa+" "+ bb);
this.cluster.Start();
private void button3_Click(object sender, EventArgs e)
foreach (VMSClient client in this.activeVMSClients)
client.Start(@"C:\Weather\Weather 2016.vzp");
//error happens here
FlaggedIID iid = cluster.Load("0000", "Icons Test ", LoadFlags.New | LoadFlags.Existing, null).Result;
using System;
using System.Data;
using System.Linq;
using System.Text;
using System.Net;
public Form1()
else
var aa = vms.ID;
Re: Remoting 4
try something. like:
client.Start(new string[] {@"C:\Weather\Weather 2016.vzp" });
Personally I dont use space in File names I always replayer them with _
Otherwise the way of starting a project and loading a scene is OK.
You should however always watch out for null-objects like the "cluster" object in your example.
Have you seen the VentuzAPISDK.chm which can be found in the start menu or the Ventuz program folder?
That in combination with the Ventuz help is an almot complete documentation of what you can do with Remoting 4.
Eric
Re: Remoting 4
Hi Eric, thank you very much for the reply, yes the space was there by mistake(I just couldn't re-edit the post to correct it.)
Here is the working code for anyone who want to try out (just replace the filenames with your desired ones..
Open c# and add label1,label2,listbox1,button1,button2,button3,button5,button6, then paste the code,
and add the reference libraries of Ventuz5.....
THIS IS NOT A FACNY CONTROLLER, just a start for a full beginner trying remoting4.
using System;
using System.Data;
using System.Linq;
using System.Text;
using System.Net;
IID activeScene = IID.Invalid;
FlaggedIID iid;
FlaggedIID iid2;
public Form1()
else
var aa = vms.ID;
// this.cluster.AddMachine(cc);
listBox1.Items.Add(aa + " " + bb);
client.Start(new string[] { @"C:\Weather\Weather 2016.vzp" });
private void button5_Click(object sender, EventArgs e)
iid = cluster.Load("0000", "Icons Test", LoadFlags.New | LoadFlags.Existing, null).Result;
activeScene = iid.IID.Value;
cluster.PortStatus("0000", 0, true, iid.IID.Value, null, null);
private void button6_Click(object sender, EventArgs e)
iid2 = cluster.Load("0000", "Weather Icon", LoadFlags.New | LoadFlags.Existing, null).Result;
activeScene = iid2.IID.Value;
cluster.PortStatus("0000", 0, true, iid2.IID.Value, null, null);
using System;
using System.Data;
using System.Linq;
using System.Text;
using System.Net;
FlaggedIID iid;
FlaggedIID iid2;
public Form1()
else
var aa = vms.ID;
