i would appreciate help with this small thing as a newbie. Can someone please tell me how to make light visible? Like a spot light. I want to add a little light show to the project, but i cant figure out how to make light rays visible.
Thanks in advance.
Frantisek
Light rays (visible light)
Re: Light rays (visible light)
hi,
depending on your needs, you could give crashzoom effect a try.
Greetings Christian
Greetings Christian
- Crashzoom.vza
- (8.68 KiB) Downloaded 218 times
Hello, thanks for reply. Im looking for something completely basic. I cant buy anything right now. I want something like a basic light, like from a concert stage, and change its color. Just the very basics. Move it around a bit, like change the direction where its pointing.
I heard it should be possible with basic Ventuz without buying something. I was looking into it for few days and i was unlucky. I was close to solving it, but not enough.
The logner ill work i will be able to buy and learn with other effects. But for now i have to work as it is now.
Thank you in advance.
Frantisek
Frantisek
Hi Frantisek,
the crashzoom is a build in effect of V5
no need to buy anything...
You could also use a cone to visualize the "lightray" in combination with a gradient texture mapped on the cone (old game development trick)
Sweet, Ill look into it, thanks a lot for your reply
